1 - 1 of 5 Posts
· Registered
Yes. Make sure you are aligning the slot on the front of the cam gear to the dimple on the back of the cam cover (black metal piece). The woodruff key on the crank pulley should be at 3 o'clock . The passenger cam mark is at roughly 9:30 and the driver is at about 2:30. I hope this makes sense. Once you think you have it all done, hand crank the crank pulley as if you are tightening the pulley bolt (24mm socket). I usually crank it 2 full rotations which is 4 rotations of the crank and then check to be sure everything is still aligned. If so, you are done. If not, rinse and repeat.
1 - 1 of 5 Posts
