Is there a trick to removing the camshaft sprocket from a 3.2 V6 SOHC cylinder head?
After removing the center bolt, I thought the sprocket would easily separate from the camshaft but I mist be missing something obvious. The FSM doesn’t call for a special tool so maybe is just a tight fit? I don’t want to damage the sprocket trying to force it off. Appreciate any advice on how to do this!
as I’m in the process of removing the camshaft assembly to get the heads inspected at a local machine shop.
thanks in advance
Mark
thanks in advance
Mark
