You truck has an electronic module attached to the accelerator pedal, this module is called the Accelerator Position Sensor (APS). The module contains three separate potentiometers identified as APS#1, APS#2 and APS#3, Each potentiometer has three electrical connections, one for the +5 Vdc reference, one for the Ground (battery negative) and one for the output signal. The total resistance of each potentiometer is; APS#1 3500 ohms, APS#2 3500 ohms and APS#3 5600 ohms. The potentiometer is a variable resistor using the accelerator pedal the mechanical input to vary the resistance causing the output voltage to operate in a range of 0 to +5 Vdc . There are three APS potentiometers with three wires each for a total of nine wires needed to connect the to APS module to the PCM. Each APS bundle of three wires is shielded with shield grounded one end.
The problem on your truck is that aliens or your mechanic has caused three of the APS wires to become open apparently inside the wiring harness between the H-6 connector and the PCM connector. This was determined by checking the continuity of each of the nine wires with the ohm meter. The only way to fix the problem is to connect a wire to bridge the broken spot in the wire.
Reconnect all the connectors except the PCM and the and APS connector and rerun the continuity test to verify the initial findings.
APS#1 +5 Vdc APS connector Pin 10 to PCM E-22 Pin 36 (Black)
APS#2 +5 Vdc APS connector Pin 8 to PCM E-21 Pin 2 (Green)
APS#3 +5 Vdc APS connector Pin 1 to PCM E-22 Pin 77 (Orange)
APS#1 Ground APS connector Pin 4 to PCM E-21 Pin 63 (Red)
APS#2 Ground APS connector Pin 3 to PCM E-21 Pin 80 (Blue)
APS#3 Ground APS connector Pin 7 to PCM E-22 Pin 41 (Orange/Blue)
APS#1 Output Signal APS connector Pin 5 to PCM E-22 Pin 68 (White)
APS#2 Output Signal APS connector Pin 9 to PCM E-22 Pin 78 (Yellow)
APS#3 Output Signal APS connector Pin 6 to PCM E-22 Pin 79 (Blue/Green)
E-21 is the Blue PCM connector // E-22 is the Red PCM connector
