Pins 1 and 4 are supposed to be grounded so they should have been zero volts, however, the resistance test shows they are actually not grounded, so both are open between the connector and the PCM or the pins in the PCM connector are not making good contact.
Pin 1 does to PCB Blue connector E-21 Pin 41
Pin 4 does to PCB Blue connector E-21 Pin 61
E-21 Pin 41 is top right right on the connector pin side ("face")
E-21 Pin 61 is on the right side just below the securing bolt
See if you can determine where the wires are broken.
