I am the original owner of a 2001 Trooper 3.5L with 204K miles.
It has burned a lot of oil for a long time and I have tried to check and refill regularly (I have read about the reason and fix for the excessive oil use). In recent months, it has begun running rough particularly at idle and seems to have lost a bit of power on the road. I was getting random cylinder misfire codes and then recently have been getting #4 cylinder misfire codes.
I did a compression test on the engine and all the cylinders are below the 'rebuild' psi listed in my digital Trooper shop manual (145 psi). The cylinders range from about 140 psi down to 118 psi with the #4 cylinder reading about 43 psi. It seems time to either rebuild or replace the engine.
I am in the process of pulling the engine and manual transmission. I haven't decided whether to rebuild or replace the engine yet. I have several questions relating to this process.
1. Do I need to pull the transmission? The manual says I do. I don't know if it's possible to leave the transmission in place and just pull the engine. If I did that, I would have to stab the engine onto the transmission when re-installing the engine. I have never done that before... I always stab the transmission onto the engine when the engine is already on the motor mounts.
2. Remanufactured engines. I don't mind paying for a reman engine but would like it to be a high quality job. Does anyone have experience with a good brand of reman engines for Troopers (in the USA)? Do the engines incorporate the oil burning fix with pistons with more oil drain holes?
3. Rebuild kits. There are numerous rebuild kits available. Does anyone have experience with a brand of high quality kits? Do these kits incorporate the oil burning fix with pistons with more oil drain holes?
I am hoping to fix the Trooper and drive it for many years to come. Thanks for any ideas!
