1 - 20 of 23 Posts
This is the thread for my 2001 Rodeo Manual Swap. I've removed the 4L30E and am replacing it with an MUA5 Transmission I pulled from the junkyard.
Removing Auto Transmission
I had a hard time removing the auto pilot bushing. The slide hammer wasn't cutting it.
I ended up having to make my own tool from a harmonic balancer puller and a slide hammer.
Pilot bearing installed
Flywheel installed using M10 X 30mm x1.25mm bolts strength 10
( I did not use the circular plate as suggested, the bolts were already 1mm short of stock)
I call this threadlocker purple.
(I cleaned the flywheel with brake cleaner after this.)
Lining up clutch and installing flexplate
(I used M8 x 20mm x 1.25mm Bolts strength 10 for the flexplate)
Getting MUA5 transmission ready (and spilling fluid)
Pushing tranny under car
Wiring up reverse and 4WD indicators
Jacking up transmission
Getting clutch and shifter area ready.
So close now. Just need to line up transmission and get the clutch fork in the throwout bearing.
I should be done next weekend.
Some more updates.
I was able to get the transmission installed and lined up the clutch fork in the throwout bearing arms.
Make sure those dowels are moved to the right place. They will be different coming from a 4L30E
Getting the transmission lined up with the splines was a bit hard. I strapped the tranny to a floor jack and then hooked the floor jack on a winch line from the back of the garage (mainly for pulling broken vehicles in).
I used the winch to pull the trans forward lining up the output shaft into the clutch. It took a while to look around the sides and rear of the transmission to make sure it was lined up with the angle of the engine. Once i had the winch pulling forward on the trans I wiggled it and it popped into the crankshaft splines.
I used a ceiling winch to help lift or lower the transmission
(I had the hood removed and the cable against the firewall
Great picture by picture details. Did you have to make "straps" to allow the crossmember to bolt to the frame like I did with my 91 Trooper? Dennis
I just had to flip around the crossmember and grind some metal down and it lines up perfectly.
So the front driveshaft from the 94 Rodeo fits on this 01 but the rear does not.
Wondering if I need a driveshaft from a 98+ 5spd 4Dr 4WD rodeo? Or maybe one from a trooper?
Some more updates. Here is wear I had to grind off the trans cross member so the front driveshaft would fit.
Also the holes needed to be bored out just a little bit so the crossmember would line up properly.
Getting the slave cylinder mounted and clutch line ran. I used a 5mm brake line with 3/8"-24 fittings. I used a fitting adapter for the slave cylinder. (The wilwood master cylinder was already 3/8 24)
Front driveshaft bolted up and crossmember on. The car is ready to drive except for the rear driveshaft.
So the worst thing happened.
The throw out bearing popped out of the clutch.
I had read about needing to weld it so it wouldn't pop out but chose not to :banghead:
Got the Rodeo into gear briefly to spin the front tires while in the air. It was a wonderful moment engaging the clutch in first gear and hearing the rpms slightly drop
pressed the clutch pedal again and tried to shift gears. Horrible noise and I let off the pedal.
I looked in the hole of the trans and found the fork had pulled the throwout bearing all the way out.
What a terrible design!
So now I will re pull the trans and pull the clutch off the flywheel and take the throwout bearing to a friend who can weld it in so it wont pop out of the clutch. :cry:
I read about that, but was concerned about blowing through the thin metal and didn't weld it. It's been holding up fine, but I wonder why some of them pop off and some don't.
Act 884006p is the part number to look for. There are other guys who have done this because of the same issue
I switched to a Luk. The design is slightly better than the Excedy but not as advanced as the monoloc.
I tried talking to the engineering and trying to get coverage for labor but of course got nowhere. They blamed it on faulty installation. And I told them you cannot install it incorrectly. it will not allow gears to shift if you get it half and half out the ears where it locks.
If I ever have to pull it down again I'm getting a monoloc
Thank you I ordered the monoloc with 4 day shipping.
No fun taking this trans back out again so I need to make sure it hold this time.
I've pulled the transmission and am waiting on the monoloc.
Those top two bolts are a pain. I don't think I'll put them in again until I verify full functionality of the assembly.
Here is a video of the throwout bearing loose and pulled out of the clutch collar. It was seated well and functioned properly initially.
[BBvideo 560,340:z26li6ci]https://www.youtube.com/watch?v=5c8s5JjtGYI[/BBvideo]
Was that excedy? If so, send it to them and give them **** for a bad design!!
I know it's stock oem too that way. They were the supplier according to Jerry so all the other aftermarket throwouts are design the same or similar.
Didn't fully understand until I watched the video. What a chickenc*** design. Now I have to see what my Subaru uses. Dennis
BTW: if you have any around, I always use a couple of longer bolts that fit the engine bell housing holes and make guide pins for tranny installs. I just cut the heads off and cut a slot with a hack saw (or cutoff wheel) to use a screwdriver for removal. On those top bolts, you might try unbolting the tranny mount and raise the back of the tranny. This opens up the area between the engine and firewall. This worked for me on the 2.8 First Gen Troopers.
Dennis is right. You can get to the top two bolts from the top of the engine if you tip if forward from the trans support underneath. I've done that and also underneath method too. I'll try to describe.
Also a body lift helps immensely. I have a one inch on mine and forget how helpful that is until I have to work on something else then I remember!
If you don't have a body lift, get some extensions to reach the top two bolts also dropping the trans bracket a bit can work, tipping the trans down exposing the top two bolts but don't tweak it too much risking ripping your engine mounts.
They can flex tho. I will say duct taping a universal joint for sockets helps too keeps it from over flexing during rotations.
Last bit of advice I don't tighten those bell housing bolts too much, the combination of all the bolts is enough if that makes sense instead of tightening them all to 50+ ft lbs I do just past snug and haven't had issues ever. Think about it. The trans is held in by the cross member and it ain't going anywhere
Discussion Starter · #20 ·
Duct tape on the flex joint seems like that will help.
I had failure yet again with the throwout bearing retainer, this time the retaining clip the monoloc sits in broke free from the pressure plate.
I'm looking into getting a different clutch kit. I bought the kit off ebay, some grip force clutch kit.
Worst part is, when I went to take the pressure plate off, I used the gun and broke a bolt off into the flywheel.
Going to have to start over lol.
1 - 20 of 23 Posts
