1 - 3 of 3 Posts
· Registered
Need to replace my transmission. Open to buying new or used. Any recommended vendors?
Also...Can I only move forward with the 4x2 Automatic Transmission for 3.5L Engine or are there other options?
· Registered
The 4L30e transmission used in 00-02 Trooper is specific to 00-02 Trooper because it employs a Pulse Width Modulated (PWM) Torque Converter Clutch (TCC) control system. Additionally, both 2WD and 4WD 00-02 Trooper use a 4L30e configured with a 4WD tail shaft. The 2WD truck uses a special long removable transmission extension housing with an integral drive shaft to make up the length of the missing 4WD transfer case. So the bottom line is you need a transmission with ID Tag is 96018507. However, according to the Moveras remanufactured transmissions catalog a 4L30e with ID tag 96023779 will interchange. My records indicate a 96023779 fits a 4WD 02 Isuzu Axiom. I recommend you call Moveras for a price quote/details.
1 - 3 of 3 Posts
