1 - 2 of 2 Posts
I was attempting to change diff fluid and noticed it needed a washer on the fill plug.
Would anyone know the crush washer size needed?
Does the drain plug need a crush washer as well? I didn't see one there from what I can tell.
Eye Automotive tire Wheel Rim Water
Super Moderator
Looks like the front diff - the drain bolt in the circumference effectively uses the (housing) gasket as a seal so I don't think it has a separate gasket.
The fill plug there I think is 18mm like the rear diff. You CAN re-use that copper one if you are in a hurry and don't want to take a drive or wait on mail. Heat it red hot then let it cool - slow or quench does not matter. Then you can re-use it and it will crush again and seal.
1 - 2 of 2 Posts
