I recently noticed my rear driver bearing seal was leaking. I checked the axle breather hose, it had some pressure built up in it due to a fouled and clogged breather vent.
I was told that I could just route a hose far up and not worry about it. I decided to give this Toyota part a try and low and behold it mounts just fine and has a perfect seal. I thought I would share it here for everyone
Automotive tire Wood Electrical wiring Motor vehicle Bumper
Font Data storage device Rectangle Gas Electronic device
Hand Fluid Wood Finger Gas
That is good to know. What about that hose fitting there in the picture?
BTW, on a 2000-mile road trip a while back, my rear pinion seal started leaking badly. I went to a shop in a small town in Nevada, and he told me the seal and bearing was shot, and I would have to go to Las Vegas to have it replaced. (He could not do it and had no parts). Cost me $160 for this diagnosis and to have the diff refilled. Laying in bed at the hotel room that night, I remembered reading something about a plugged up vent. Next morning I checked it and sure enough, that is what it was. I removed the vent and ran a hose up to behind the spare tire. The leak stopped, and it has been over a year now with no problems. Lesson learned.
For my model 2000 Trooper the hose fitting in the picture seemed to be a fixed, and welded into that tubular cross bar. That is a familiar sounding story. I recently found a "trust worthy" mechanic who did my timing belt (ironically also didn't fill my 4l30e properly & coolant reservoir properly). He told me my rear bearing was leaking and needs to be replaced for 180$ just labor lol.
My rear differential is making the whine sound though, only when I accelerate at freeway/highway speeds. Let off the gas and no sound. If I coast no sound.
I wonder if just low/old differential fluid could possibly cause the sound.
Oh, I get it. The breather and hose fitting is on the cross bar and then a hose goes from there to the fitting on the diff.
I would definitely try fresh gear oil first. I hope it is that simple!
I wonder if I may have this problem, as well. No leaks to be found, but when I unscrewed the fill bolt on my rear diff to check fluid level, I was surprised to hear a powerful hissing sound. Seemed like there was a lot of pressure build up in there...
