Hey Dennis. I went out and tried to move that intake cam 90 degrees counterclockwise so that the stamped, painted arrow would be at 12 o clock with the engine at TDC, but i only made it about 45 degrees and it would not turn anymore. I put a fair amount of pressure on it to try to turn it more but not a significant amount because I do not want to bend any valves. Is this info helpful? Thank you!!
Reply to discussion #16
New on this planet myself. I’m no expert. I own an ’03 Rodeo 2.2l, and did this timing belt change several years ago. You have the cam marks in the right place, but your cam may still be out of position.
Moving that cam 90 degrees while installed will cause a collision on one of your cylinders, being an interference engine. If out of position, the cam will need to be removed and reinstalled in the correct position.
Take a look at that link Dennis sent you, particularly related to the cam index pin positions. Page 5, figure 3 shows the pins on the end of the cams. Page 10, figure 7 shows the different positions for those pins to be placed in the sprocket depending on whether it is an exhaust or intake cam. One or both of those pins being in the wrong position is my bet for your timing issue. The PO may have messed up the pin positions and now its hidden.
You would need to remove the cam sprockets to check this, or at least the bolts holding the sprockets on. The index pins may be visible under those washers. There is a hex on the cam within the valve cover that can be wrenched on to counter the rotation of the sprocket while removing the bolt.
Apologize for jumping in. I just think Dennis had the answer, and you missed the pin info in the link. I never knew the pins were there, but I also never removed my cams or sprockets.
The 2.2l is pretty underpowered and it eats oil, but with the 5spd, it’s been very reliable and fun.
Good luck.
