1 - 1 of 1 Posts
Can anyone help me with my 2000 Honda Passport? It is stuck in 4 wheel drive and I see some others have had this issue too but I don't see a solution that could help me. I have replaced the SOFT box, the front actuator with used ones from the junk yard but I just can't figure out the mechanism of the actuator. I have 12 volts registering on pin 5 when in 2 wheel but nothing once I switch to 4 wheel drive.
From July 27th 2020 Buster28 gave the drawing of the actuator harness diagram. When I have the front actuator off, when I alternate voltage on pins 3 and 4 should this make the actuator move one way and then back the other on a bench test?
Thanks for any help
1 - 1 of 1 Posts
