241 - 249 of 249 Posts
· Registered
This build is awesome! I finally have a turbo manifold on the way and am in the process of making a conversion plug for the factory harness to plug into my mega squirt. Could you send me your tune file? That would help a lot with me getting started. This is my second turbo mega squirt project, first one was an 84 Nissan 200sx. You mentioned you are using 55lbs injectors, do you remember what vehicle they were off of? Also, are you using an adjustable fuel pressure regulator? And if so, do you remember what you have your fuel pressure set at?
Thanks! -Matt
· Registered
Discussion Starter · #242 ·
I'll need your email to send you the writeup and tune. I bought the 55lb/hr injectors new online, I believe the first gen DSM injectors will work but it's been awhile so you better double check. And I am just using the stock fuel pressure regulator since it already varies pressure based on manifold pressure.
· Registered
update?
