Hi, I'm having some problems with my 2.6, any help would be appreciated.
Some background info: A couple weeks ago i was driving home and got a horrible missfire and a ton of white smoke out the exhaust...figured the head gasket blew, tore it all apart to find the head was cracked. I bought a new head, gaskets, etc. and bolted it all back together. I also changed the timing belt and tensioner at this time. All of the timing marks were lined up (crank mark pointing up, and cam mark pointing to the notch on the timing cover) and set the tension as instructed.
The engine turns over just fine, but when I try to start it i get nothing. I checked the ecu codes and it's throwing code 41, crank angle sensor. I've since done some research and found that this is located inside the distributor. The marks on the distributor are all lined up properly and i have spark. I'm not quite sure what else could be wrong.
Any suggestions? The truck ran fine before the head cracked, and i find it highly unlikely that the distributor just happened to go bad at the same time.
Again, any help would be highly appreciated.
Kyle
Kyle
