1 - 2 of 2 Posts
After 18 years, the starter in my Trooper just went out. I can't complain......but
How in the #$&@ do you get the top nut off the starter??? With the EGR tube in the way, I can't get enough leverage. Any help would be appreciated.
REMOVE THE CHARCOAL CANNISTER , AND BEND THE BRACKET OVER OUT OF THE WAY AND THEN TAKE A 14 MM SWIVEL SOCKE ON A RATCHET AND REACH RIGHT OVER THE TOP PLENTY OF ROMM YOU CAN EVEN TAKE THE BOTTOM BOLT OFF FROM THE TOP JUST BY LEANING OVER THE FENDER AND THEN PULL THE STARTER UP ENOUGH TO GET THE CABLES OFF AND THEN LIFT IT OUT BE SURE YOU DISCONNECT THE BATT FIRST. , THE ABSOLUTE QUICKEST WAY TO GET THE TOP NUT IS TO USE A GOOD AIR RATCHET AND THE 14 MM WOBBLE SOCKE ,NOT A DEEP WELL PUT THE SOCKET ON THE NUT AND HIT THE TRIGGER AND IT WILL COME RIGHT OFF . JERRY
1 - 2 of 2 Posts
