This post is for anyone looking to do a Weber carb swap on the 2.6.
Seeing as the 2.3 intakes are getting hard to come by ( seems like I looked for a year) I bought a “2.3” intake off eBay and upon further inspection and talking with Dennis on this forum figured out I had received a 1.9 intake.
Only saw one post where a guy had tried it, but never posted a follow up.
Differences that need to be addressed to make it work:
1.Tig weld up little water jacket hole over 4th cylinder.
2. Cut out aluminum block off plate and tig weld it to the fuel pump gap,
3. Get new (straight) thermostat housing
4. Specific Weber adapter for the 1.9
5. I kept the egr per Jerry’s advice, cut my 2.6 pipe, and straightened it out welded it straight, it will be just long enough. Also note if egr is desired, valve is on the bottom, can’t be added or taken off once intake is installed, A/c compressor in the way. Which also makes #2 bottom mounting bolt a real bear. Must remove power steering pump, and brkt.
I will post pics, just got it running today, got timing at 8 or 9 deg, will play with it to see optimal. Any questions or comments let’s me know. Note not as easy as a 2.3 intake, but it is doable if only option…
