1 - 1 of 1 Posts
Banned
I took this 2.3 head to the machine shop and had them do a valve job replacing all the valves with 2.6 valves, replace the valve stem seals, pressure check, and mill as necessary. Then I pulled a later model 2.6 cam with the higher lift and duration and cherry picked through my parts bins for rocker arms, shafts, etc and put it all back together. This was my way of making use of an otherwise miserable day below freezing, stuck inside. Looks like it's gonna be Spring before the RS is running, but at least now the head is ready to go.
P1080514 by johnscharnhorst, on Flickr
P1080518 by johnscharnhorst, on Flickr
1 - 1 of 1 Posts
