1 - 2 of 2 Posts
So I can get a 89-91 CALMINI lift kit cheap missing shocks. I have a march of 1989 manf date. wich calls for the 86-89 lift kit What is the differnce in the lift kits. Is there something I can swap out on my trooper to make this lift kit work?
Pre June 1989 Troopers have a different size torsion bars. You can change the mounting hard ware for the TBs using post June 1989 Trooper parts. You would need the front sockets and lower control arm bolts (large bolt that hold the control arm on) and the rear adjustment arms from a donor truck. It is a simple conversion if you can find the right Trooper in a wrecking yard. I have a pre June 1989 Trooper that I just changed over so I could use the cheaper HD Sway-A-Way TBs and was one of the easiest mods I have done on the Trooper. DAVE
1 - 2 of 2 Posts
