1998 Isuzu Rodeo S 3.2 4X4. The temperature gauge is reading hot. It may be hot, but I am not sure. The IR reads 170F on the upper hose. There is probably some variance for testing on the hose. It also reads 150 on the lower hose. About two years ago I replaced water pump.
The gauge has been reading three three lines below for right wide line. However, it has gone to the wide white line. It has gone beyond the wide white line. I would expect to see steam coming out of the cooling system if overheating, but I don't see any. Furthermore, I am able to take radiator cap off while testing at home after 15 or 30 minutes.
In past two weeks:
I changed single wire temperature sending unit for gauge from Auto Zone, then I replaced that one with O'reilly.
I changed coolant temperature sending unit two wire for computer.
I replaced fan clutch, and condenser fan.
I change antifreeze and radiator cap.
Afterwards still reading hot.
Checked compression 140 to 170 all cylinders
No antifreeze consumption
No exhaust bubbles in coolant
No water in oil cap
No visual overheating
No smoke from tail pipe
No rough idle
It has normal power
Codes: VSS and EGR. Changed both. Then no codes.
I replaced IAC solenoid.
Upper and lower radiator were getting hot with variance of 20 degrees. I saw fluid traveling in the radiator, so I was sure thermostat was opening and water pump was working and radiator was not clogged.
Just in case the thermostat was partially stuck closed, I changed it knowing it was a big job.
Thanks to Matt Payne's Intake Manifold video, I replaced the thermostat with Napa THM 376170, and I replaced intake manifold upper and lower gaskets. I replaced all the parts under intake manifold: hoses and knock sensor plus heater hose. Change throttle body gasket for maintenance.
I located OEM radiator for $99 on Ebay, and I replaced that too.
Afterwards still hot.
I double check the fan blade direction using Matt Payne's video, and it is the same.
I checked fan clutch and it engages, but I am not sure when it suppose to.
Where I am with this issue. I ordered a scan tool which will arrive Tuesday, so I can see coolant temperature according to OBD2.
I plan to purchase Isuzu OEM temperature sending unit.
I plan to perform a combustion leak test for Exhaust Fumes in the Antifreeze.
What I am hoping is that someone can tell me there is a known issue of some sort and what it is that would make the gauge read hot. Such as instrument panel, or using aftermarket sending unit. I hope for suggestion for a good combustion leak test to test for Exhaust Fumes in the Antifreeze.
I changed water pump two years ago, which was another big job. I am looking for a good reason to tear this apart.
In past two weeks:
No water in oil cap
No rough idle
It has normal power
