Hello,
Recently got my Passport running after sitting for a year. Did a transmission fluid/filter change, some clutch material in pan, not terrible. While driving on the highway at 60mph, the dummy lights came on, and the code was P1870. I've done some research, and I think it's either(in order of hopefulness):
1. TCC solenoid gummed up or failed
2. Vehicle output speed sensor failed/failing
3. TCC friction material gone
4. Pump not producing enough pressure to lock up TCC
Can the 4L30E throw a P1870 if the TCC solenoid is bad? Wouldn't it throw a P1860 instead? Can a failing vehicle speed sensor cause a mismatch between the input and output speed readings and cause a P1870?
I am going to test the solenoid from the connector on the outside of the trans, I believe it has to have a resistance between 17.5 ohms and 18.5 ohms to pass.
Thank you in advance, I'm going to go crawl under my truck in the rain and see if I can get a resistance on the TCC solenoid.
