There are 2 small hard to get to coolant lines coming off the bottom of the thermostat housing and they both go to the front of the head L&R...one is very soft and swollen and I would like to try a quick fix and replace it...Yes, they appear to be part of a T- hose connector...how do I go about finding the correct replacement hoses and is there a special process to remove and replace them? What type and size hose to use (fuel line hose?). It is a small and tight space. Will I still be able to remove the spring clamp on the hose at the head?
Hose in pic is on the front passenger side.
Thanks
Thanks
