So the a/c was working great, thought I had it fixed then suddenly on the way home it started blowing warm air. I got home and checked the pressure on the low side....it showed way too high at near 75 psi and the line was warm to the touch (low side). The high side is hot to the touch. I pulled the cover for the relays under the hood and seen the a/c com relay was steadily "clicking". The a/c clutch wasnt turning. I pulled the relay and jumped the a/c clutch wire to force the compressor to run. The low line started getting cold and the air inside was blowing nice and cold again. But if I pull the jumper wire and plug the relay back in, it just clicks steadily and the a/c clutch will not turn.
Ambient temp outside is near 90 degrees (very humid) and the vehicle temp is up to temp (normal operating temp).
Why can I jump the a/c clutch wires and have it blow nice and cold but the relay will not let it come on? Why does the low pressure line have such high psi pressure once the vehicle gets to normal operating tempature?
