1993 Rodeo 2WD 4ZE1/T5 CA Spec - 2016 RAM1500 Pentastar (22mpg) - 1986 RockZuk on Toyota Axles
Hey, first post, have spent the last week reading all about the various trucks and issues in a pre-OBDII 2.6
My wife likes to drive a manual and I found her a 1993 Rodeo with the 2.6
It was running with functional A/C when we bought it, it ran a little rough but to me just looked like they'd bypassed too much of the CA smog equipment and left to many unplugged places for vacuum.
I've got it back together and it ALMOST starts but won't. It's cranking, sounds like there's some ignition, but it doesn't actually fire up. Felt like the computer is stopping the injectors getting fuel. It threw codes for TPS & ECT, so I figured I broke off some of the sensor circuit. Went back in and for sure the TPS wasn't plugged all the way in, and I broke off the little condensor/resistor. Problem I have left is that I've got 3 loose wires down by the starter, it has to be for both the oil safety switch and the oil sensor. They're all either broken off or replaced with a spade connector, one blue, one yellow, one black. I only have one switch/sensor/sender, and it just has a single spade connector on it, and it's right by the starter. The spade looks like it could have been jammed inside there as a backyard mod to get the thing running, could have been an oil pressure safety switch/sensor with two or three wires at one time.
The single wire to the condensor/resistor has continuity to the TPS but neither battery cable, I'm thinking I could figure this out by continuity testing that wire to the wires down below by the starter, to identify which two are on that sensor circuit with the condensor and TPS sensor, to connect them together get the ECM to let the thing fire up.
Any advice? Maybe even connect all 3 of them together at the single spade connector on the one oil sensor I do have on the truck? If the third is a ground would that damage the ECM? I realize I won't have a functional gauge or idiot light, but this car doesn't need to go very far ever. Mostly just for her to get to work 1 minute down the way, have a place to keep her stuff, and have something air conditioned to sit in on her break. Please help! (Cuz I secretly really really like this truck and think it's fun to work on)
