1 - 4 of 4 Posts
Recently had Head shaved on Rodeo (4cyl) Put it back together and it will not run. It will crank, but will only idle for about 30 seconds then dies. Timing has been set. Rechecked all vacuums. All electrical plugs were checked. If anyone has any suggestions please help me. :?
Are you sure the cam timing is right? Can you hear the fuel pump cycle on when ignition is turn on? Was it running before? Or did it sit for a longtime? Check fuel filter & old gas?
Slow on the reply :( Is it running now?
1 i pulled the tank checked pump it works fine on a battery.i canot hear it when i turn on ign,switch
1 - 4 of 4 Posts
