holy grail of fuel economy
DIESEL!!!!1 :lol:
and betta yet, with the veggie oil conversion kit:
http://www.greasel.com :lol:
TIRES: If you have the 31s, they are LT grade, meaning 6-ply. A definite plus would be to scruff up some stock rims and put P grade tires on for commuting because they are 4-ply and thus lighter in weight so the engine doesn't work as hard to 'push' them and keep inertia. Keep the snowflakes with the heavier 31s for wheeling events. OR, if you know that you aren't going to use those larger tires but very rarely for wheeling, dump the LT grade 31s for P grade 31s.
Yep, bump up to at least the max PSI. If they are the stock size for those rims, which are 7.5" wide and your tires are 10.5" wide, then you 'should' be able to run at max pressure with undo tire wear.
Another option is to move from an AT tire to an efficient highway-only rated tire to maximize fuel efficiency. I plan on doing this very shortly since my Troop will once again become a daily driver and the 32's suck fuel like an oil tanker........
If the truck sat for a year, I'd definitely consider several oil changes alternating between 5W and 0W in short intervals to help clean up any gunkiness and even using Sea Foam as well as perhaps a seal conditioner. The 3.1 is a fairly stout engine with good care although you may be looking at a water pump or alternator soon.
All other fluids should be changed including radiator, oil, front and rear diff fluid, power steering, transmission (manual is no big deal, auto is another matter - could open a can of worms), clutch (flush), and brake (flush) to "0-Time" all the fluids so you physically know exactly where they all stand irregardless of what the prior owner documented/said.
Service Manual:
http://www.helminc.com
Cheers,
