1 - 4 of 4 Posts
Hey Gang ! Thanks for the help on the driveshaft concerns. Turned out to be a loos pinion nut, but now I'm digging in a replacing the bearing and race. While under the truck I found why it clunks when I make a turn! Leaf spring shackle bushings are shot. Front, rear, upper and lower all need replaced. Whats the consensus on best replacement options? May be throwing some bilstiens on at the same time to up the tongue weight a bit. Main goal is to fix the bushings and be able to put a motorcycle on a hitch hauler. Please Help!
Thanks Gang
1986 Isuzu Trooper II
Automotive tire Wood Rim Motor vehicle Automotive exterior
Tire Wheel Automotive tire Tread Motor vehicle
Are you sure it's the shackles? I have a 1986 that has the upper shackle mounts rusted out that make/made them not work properly because they flexed sideways.
For shackles, I made a custom set out of some steel plate, but there are options:
and
1 - 4 of 4 Posts
