The wheel weights are hitting, I have calmini control arms with 1/4 ball joint/flip spacers
It doesnt look like the stops will adjust out enough
Any ideas
Thanks
Tony
OregonCity OR
Correct me if I'm wrong but if you have the Calmini UCAs you shouldn't need to use bj spacers as the angle correction is already built into the arms. I'm wondering that in using both you pushed the arm higher off of the knuckle than it should be and that's why you're running into clearence issues
Bingo!
