My swapped 3.4L V6 is idling about 1200-1800 RPM after its been running for about 5 min. The throttle body and intake are original from 2.8L but problem recently started. I have replaced the IAC but no effect. I do not see any open vacuum ports or hoses breached, and the throttle valve fully closes and is not sticking at idle, and timing checked.
I do not think there are any air leaks around TBI gasket and injector spray pattern normal. I am getting normal engine temps on gauges (but I suspect there is a 2nd temp sensor for ECM) and no check engine light.
Any suggestions appreciated
