1.9 vs 2.2 DSL engines
405 Views 10 Replies 4 Participants Last post by  Bahahatrooper
Does anyone know how to tell the difference between the 1.9 and 2.2 DSLs? I have two motors and I'm not sure which they are and need some help identifying them. Thank you.
Post a picture of each and myself or someone else could likely tell which is which
Reactions: 1
Well, there's no 1.9 that I'm aware of. The 4FB1 was 1.8L.
Besides the casting on the block, which itself it pretty conclusive --
The 1.8L is an OHC engine, with intake on one side, exhaust on the other.
The 2.2L (C223) is an overhead valve (pushrod) engine, with both intake and exhaust on the same side.
Jack
Reactions: 1
Jack
I found the casting mark on the side of the engine. The one I just acquired is a c223. I haven't made it to look at the other at my shop. The 1.9 is a diesel. The c223 that I just got is a diesel also. I'll post an update as soon as I can.
Is the 1.9 diesel you are talking about a C190? Those were never sold in any US passenger vehicles so it is likely a utility engine of some sort.
Reactions: 1
I found the casting mark on the side of the engine. The one I just acquired is a c223...The c223 that I just got is a diesel also. .
Of course it is. All C223s are diesels.
^^^^ What he said. ^^^^
That is what I was talking about. I was lead to believe they were put in the earlier luvs.
Upon closer inspection they are both c223s. Thank you all for the help.
Not in the US.
Reactions: 1
Glad you already found out that both are C223
Automotive lighting Automotive tire Motor vehicle Automotive design Wheel
C190 (found in LUV, Isuzu Faster and Isuzu Florian) use inline type injector pump and use valve to close the air intake to shut down the motor.
C190 revs higher than C223 but less torque
Andy
Reactions: 1
Andy
Thank you for the information. Yes both being the same just means I have to order two of everything!!!
