Hi. Back again. I have the '01 Trooper which I thought the transmission was slipping. I changed the range sensor and it didn't cure the problem. I noticed that in lower temperatures the transmission does not want to shift. What could be the problem? Has anyone experienced this? Would it be a sensor problem? Any help or suggestion will be greatly appreciated.
Thank you.
Thank you.
