1 - 2 of 2 Posts
Hi folks.
I've decided to sell my '01 5spd and I have a few small things to set right first.
I had to remove the power mirror from the driver's door and I found the wiring harness plugs under the glass are disconnected.
How do I get to those? It looks like I'll have to get the glass off but not sure how. Heat maybe?
TIA
I realize now that I posted this in the wrong area.
However, having broken the mirror glass, I can attest now to how the glass itself is attached. There was a heavy bead of rubbery white adhesive on the back of the glass.
I suspect heat would have helped to remove the mirror with less chance of breaking.
I hope this helps somebody down the line. The silence can be deafening....
1 - 2 of 2 Posts
