1 - 4 of 4 Posts
Ok I’m new to Tucson AZ and temps dropped to the 30s (So cal guy) 8) I don’t know if this is a factor.
When the truck is cold (and my wife is driving) the brake light stays on after disengaging the parking brake. :? If she stops and restarts all is A-O-K.
She has no problem with the brakes other than the light.
No she won’t let me put a piece of black tape over the light.
Any Ideas? :idea:
Thanks
Rob
Check your brake fluid. That's not just a emergency brake light, it also tells you if you are low on fluid.
Joe
Levels are fine. The only variable is the cold.
If there is a level switch in/on the brake fluid reservoir, check for moisture in the switch/connector. Lots of times when it cools, the moisture condenses and shorts the switch.
Joel
1 - 4 of 4 Posts
