2.8L V6 ICM Location
Postby blairbo » Sun Jun 18, 2017 11:39 am
Hey guys trying to do some trouble shooting on my trooper. Can anyone link me a picture of where the ICM is actually located. I have a 1990 Trooper with the 2.8L V6.
Thanks
blairbo
Re: 2.8L V6 ICM Location
Postby DSUZU » Sun Jun 18, 2017 2:11 pm
center console. the tray is removable and ecm is under it. Dennis
Has thanked: 220 times
Have thanks: 624 times
Postby geoffinbc » Sun Jun 18, 2017 2:25 pm
The ICM is a little blacl box under the hood. The ECM is under the console.
Have thanks: 324 times
Postby gwana66 » Sun Jun 18, 2017 2:50 pm
http://www.isoterra.com/isuzu/planetisuzoo/IMG_5927.jpg
See if that link works. The Ignition Control Module (ICM) on the 2.8 is the black object under the distributor rotor. Use ONLY AC Delco if it needs to be replaced. The others will fail.
Even the hubs are manual now.
2003 Grille and headlight swap
For this post the author gwana66 was thanked by:
gwana66
Has thanked: 12 times
Have thanks: 205 times
Postby DSUZU » Mon Jun 19, 2017 4:35 pm
:oops: My bad! ICM, ECM. Well at least I didn't tell him where to find the ICBM - He might be Korean. Dennis
Postby blairbo » Fri Jun 23, 2017 7:04 pm
Thanks everyone. that made my life much easier.
blairbo
Return to Drivetrain Problems
