Thinking about a purchase (edited: it made it, pics 6/20)
Postby The Bear Jew » Thu Jun 15, 2017 6:28 pm
There is an 88 Trooper in my area that came up for sale for $800. I spoke with the guy today and he said that the head gasket is blown and the A/C doesn't work.(which I am equipped to replace in my garage). Other than that he said the truck is mechanically solid. The body looks ok for the age in the pictures and the interior is better than a lot of them I have seen. I figure worst case scenario I need to get a head for it and the auto parts store near my house can get them for $450. He also to told me that despite the head gasket being blown it runs fairly smoothly and they didn't allow it to overheat. The diagnosis of the head gasket came from the exhaust smoke initially then checking the dipstick and seeing that their was water in the oil.
What I am wondering is, is there any tips or tricks for me when I go see this thing hopefully this weekend? Is there anything that you would make you scream deal breaker?
Thank you very much for your help in this and I will update when I check it out! *Fingers Crossed*
EDIT: he also stated that he had just replaced the fuel pump when the head gasket went out.
1989 Trooper SE 5 speed
1979 Mustang 351W (bored and stroked 393) :twisted:
2000 Civic auto (fiances car)
The Bear Jew
Re: Thinking about a purchase
Postby wmorrisiii » Thu Jun 15, 2017 8:28 pm
Frame rust is the only real deal breaker for me. Having fixed and reinforced a bad one, it is an ongoing effort to control the rust. Fixed is a misnomer, it isn't really fixed, I am just prolonging the inevitable for as long as I possibly can. Who knows how long but I think the POR 15 and Eastwoods folks love having me as a customer. Look for rust rear wheels back, rockers, and lower parts of door panels. You are in SC so you aren't in a salty roads state so a truck that has lived down there for most of its life should be better than what you would see if you started looking north a few hours. Good luck finding the one you want, and 800 bucks sounds fair for what he is asking for this one. Also, thumbs up on looking to bring another first gen back to life!
Willie's 1990 Trooper LS, 2.8L
The Duck Marsh Debutante
Willie's 1987 Trooper LS, 2.3L
The Coonhound
wmorrisiii
Has thanked: 87 times
Have thanks: 178 times
Postby gwana66 » Fri Jun 16, 2017 1:01 pm
One caution on water in the oil - it won't take long to wipe out the bearings. If it was driven that way for any length of time you could have some damage in the bottom end.
Even the hubs are manual now.
2003 Grille and headlight swap
gwana66
Has thanked: 12 times
Have thanks: 205 times
Postby The Bear Jew » Fri Jun 16, 2017 7:17 pm
Thanks for the responses so far, I will definitely take those into consideration. Unfortunately they are going camping this weekend and I won't be able to go see the Trooper until Tuesday. But in the mean time if there is anything else, please let me know!
The Bear Jew
Postby DSUZU » Sat Jun 17, 2017 6:50 am
If you can, check the crankshaft end play (just push / pull on the pulley, maybe with a medium screwdriver. If it has say 1/8" endplay, the thrust bearings have failed and the block will most likely be shot. I say this because used engines are getting more difficult to find. Dennis
Has thanked: 220 times
Have thanks: 624 times
Postby The Bear Jew » Sun Jun 18, 2017 9:20 pm
Leaving the house at 10:00 tomorrow and heading to NC. Hopefully this is the one! Ill update and let you guys know what happens. Thanks for all of the replies and i will def be checking everything you guys mentioned.
The Bear Jew
Postby The Bear Jew » Mon Jun 19, 2017 3:57 pm
Im here and i pretty sure im gonna buy it, just trying to figure out how to get it back to my house. 0 to almost 0 rust. Very liitle if any endplay on the crank pulley. There is no and an after market lock cylinder is wired in so ill have to solve that. It smokes like a chimney after a few min idling but it looks like headgasket like was mentioned in the ad so not to worried. Still runs pretty strong tbh.clutch feels good as does the tranny in all gears.
I can post pictures but i cant figure out how to get them to be smaller than 4mb. When i get home ill try it on a computer.
The Bear Jew
Postby The Bear Jew » Mon Jun 19, 2017 9:04 pm
So, story time, the owners said they would tow the truck back to my house. about 20 min from their house the dolly tire blew out. so the truck is sitting at his cousins house until hopefully tomorrow when I can get a uhaul and a dolly to get it back. got to love it when a good plan comes together.... but hopefully tomorrow will be the day :|
The Bear Jew
Postby The Bear Jew » Mon Jun 19, 2017 9:05 pm
1 last pic for now, also how would you guys suggest pulling this thing with a dolly. I did it with tranny and t-case in neutral, is this correct?
The Bear Jew
Re: Thinking about a purchase (edited with pics 6/19 9pm)
Postby oldestisuzuist » Tue Jun 20, 2017 12:21 am
There is no neutral in the t-case, unless you disconnect the rear drive shaft the mainshaft of the tranny will spin throughout the tow.
If the tranny has sealed bearings on the mainshaft no problems, if non-sealed bearings they can fail since they lube by splash via the gears turning- which they aren't when in neutral. Since you don't know what type bearings are in the tranny be safe & disconnect the driveshaft at the pinion yoke & secure the loose end.
'78 LUV, 1.9, headers, 4-spd, SAS Dana 30 front, Dana 20, SOA rear w/Aussie Locker, 31's, serious body cancer, bought new 12/4/78.
'87 Trooper, 2.3, headers, 5-spd, 31's, ball joint flip, Aussie Locker rear, Superwinch hubs, brush guard w/5.5K winch, needs motor, work in progress.
oldestisuzuist
Have thanks: 251 times
Postby The Bear Jew » Tue Jun 20, 2017 6:39 am
O ok, I was under the impression that the t case not being in gear was "neutral" I was mistaken. I will disconnect the driveshaft if at all possible, any idea what tools ill need. I have a bunch of tools just don't want to not the bring the one thing I need lol.
The Bear Jew
Postby paulevans76 » Tue Jun 20, 2017 9:37 am
I'd probably just put the rear tires on the dolly, but I'm no dolly-tow expert. I'd pony up another 25 bucks for a trailer more than likely ;)
91 SAS Trooper - Neverending tinkering
Semi-hopped-up 3.4 + MUA5 + 3.07:1 low
Waggy D44 Front - 5.38's + RCV's + OX
Rodeo D44 Rear - 5.38's + Detroit
35" General Grabber X3's on Interco Birddogs
Has thanked: 92 times
Have thanks: 87 times
Postby Van » Tue Jun 20, 2017 10:13 am
Get that thing fixed and you can join us at Beasley Knob this weekend. :idea:
Welcome to the Upstate. :thumbup:
Van
Has thanked: 22 times
Postby The Bear Jew » Tue Jun 20, 2017 12:54 pm
Its on its way home! Wish me luck!
The Bear Jew
Postby The Bear Jew » Tue Jun 20, 2017 3:08 pm
Van wrote:Get that thing fixed and you can join us at Beasley Knob this weekend. :idea:
I wish I could! knowing the parts stores around here ill probably be waiting until this weekend for the wrong parts, then Ill have to wait another week for the right ones. But if by some miracle it works out Ill give you a shout.
The Bear Jew
Re: Thinking about a purchase (edited: Its on its way home!)
Postby The Bear Jew » Tue Jun 20, 2017 7:51 pm
It made it, im going to be doing a build thread on here when i get started so hopefully itll be interesting for some of you
The Bear Jew
Re: Thinking about a purchase (edited: it made it, pics 6/20
Postby wmorrisiii » Tue Jun 20, 2017 8:46 pm
Looks great, congratulations, let the fun begin!
The Coonhound
wmorrisiii
Postby The Bear Jew » Tue Jun 20, 2017 8:51 pm
Thanks! Haven't been this excited about a project since i built my mustang a few years ago. Cant wait to dig into this thing and see how its put together. First thing is a solid cleaning tomorrow, then undoing alot of not so great workmanship and a new headgasket/timing set while im in there.
The Bear Jew
Postby wmorrisiii » Tue Jun 20, 2017 9:02 pm
In a week you will wish you had tiny little Japanese hands and arms :lol:
The Coonhound
wmorrisiii
Postby holger » Tue Jun 20, 2017 10:14 pm
wmorrisiii wrote:In a week you will wish you had tiny little Japanese hands and arms :lol:
... and strong, like a samurai's hands ...
Oleg
Axiom 4WD 2004
ARB front locker; No-Slip rear; bent rear flexible links; TC coils, 2" spacers; extra long shocks; adjustable track bar; IronMan torsion bars; etc
holger
Has thanked: 32 times
Have thanks: 44 times
Users browsing this forum: Google [Bot] and 1 guest
