Rear Security Cover for Rodeo Sport/Amigo -
2005, Aug 11 Maybe a color-matched cargo cover to protect your gear |
'86 Trooper Restoration -
2005, Mar 02 Pictures of James Heina's '86 Trooper |
Independent 4x Offers New Upgraded Brake Lines -
2005, Jan 01 These new brake lines offer improved braking performance and longer length for use with lifts |
Torsion Bar Adjustment -
2004, Jun 13 If you are lifting your Isuzu for the first time, this is a must read |
Replacing the Fuel Sending Unit on a 2nd Gen Rodeo -
2004, Jun 10 If your gas gauge is off, or not working at all, read on for the instructions to replace it yourself |
Mexico Border Trail, Arizona 2004 -
2004, May 19 Planetisuzoo member Scott Brady submitted this trail report, based on a recent trip he took to Arizona |
Isuzu IFS Lift -
2004, Apr 15 Straight from Thailand, some pics of an IFS drop lift. |
Vac Hose Pics -
2004, Apr 03 2.6 Vaccum Hose Routing Photos |
Aluminum Can Stove -
2004, Jan 16 How to build a camp stove from two aluminum cans |
An Isuzu Competes in MudBog Competition -
2004, Jan 06 Trooper owner Jason E. Definitely Has Gone Farther! |
4-HI conversion for TOD equipped Isuzus -
2003, Nov 26 This article is a How-To describing how to add 4-hi capability to Isuzu vehicles with TOD. |
Biography of a Madman (The Saga Continues!) -
2003, Nov 25 Things hardly ever go as-planned... Rubo's ambitious Franken`Zu Project is no different.
Uwharrie - July`03 Review -
2003, Oct 07 A look back at the Uwharrie ‘Welcome Home David Chang’ Run. (Lots of photos - Dial-up beware!)
Adding a Body Lift to a `95.5 -`97 Rodeo -
2003, Sep 17 EVERYTHING in the world you'd ever want to know about adding a body lift to a `95.5 to `97 Rodeo (I hope) |
A Biography of a Madman -
2003, Sep 02 When modifying your Isuzu, make sure that you have not bitten off more than you can chew! - This is the story of someone who appears to have done just that...
PS Hose Replacement -
2003, Jul 15 How to replace the Pressure hose on a '92-'96 Isuzu Trooper |
Venting the 5-speed MAU5 Transmission -
2003, Jun 25 Don shows us how to properly vent the MAU5 transmission to eliminate leakage. |
New Planetisuzoo Forums -
2003, Jun 23 Come enjoy our new forums at: http://forum.planetisuzoo.com |
Chuck Has Created Another Monster Isuzu -
2003, May 05 Chuck of Chucks Trucks has build another Huge Isuzu riding on 2.5 ton running gear and tractor tires. |
180 Amp Alternator on the Isuzu 3.2 -
2003, Apr 17 Here is the answer to pricy replacement Hitachi alternators on the Isuzu 3.2l engine. |
Reinforcing the Surco Safari Roof Rack -
2003, Mar 17 The Surco roof rack is a good light weight rack, but the floor leaves something to be desired. Rear on for a solution. |
Isuzu Vehicles Go Farther Both On and Off Road -
2003, Jan 19 Isuzu has released a summary of Isuzu in racing, both on and off road |
Isuzu Dealer Stock Dec 2002 -
2003, Jan 19 American Isuzu Motors, Inc. has released the Dealer stock numbers for December 2002 |
Installing a CB in the dash of a Trooper -
2003, Jan 18 Read how to install a CB radio in the 2nd DIN slot in your Truck |
Replacing Light Bulbs in Isuzu Switches -
2003, Jan 17 Has the bulb in your fog light, seat heater or cruise control switch burned out? Read this to learn how to replace it. |
ARB 10-bolt Lockers on Sale -
2003, Jan 09 Been thinking about getting a locker? Now is your chance! |
Relocating the ECU on a 2.6 Trooper -
2002, Sep 29 Move that ECU up from the floor to a spot higher above the water line |
Rebuilding the Trooper Steering Box -
2002, Aug 18 Sam gives us a tour of the inside of the Trooper, Rodeo, Amigo and Pup Recirculating Ball steering box |
Cassville Trail Report -
2002, Aug 16 David Nivens went and did some exploring near Cassville Missouri - Read about it here |
Uwharrie 2002 Review -
2002, Aug 12 Adam Crews describes another fun trek through Uwharrie National Forrest |
Adjusting Recirculating Ball Steering -
2002, Aug 12 Does your Trooper, Pup, Rodeo or Amigo have too much play in the steering wheel? Here is how to adjust it. |
Isuzu 3.0TD Engine -
2002, Aug 12 Take a peak at the diesel engine that is available in the Isuzu offerings overseas. |  |
3.4l Install Notes -
2002, Jul 15 If you swapped your 2.8 V6 for a GM 3.4, or are considering it, read this for a bit more information. |
2.6 AC Idler -
2002, Jul 08 Is your Trooper or Amigo loosing AC Belts? Here is the fix. |
XM Radio is here! -
2002, Jul 01 XM Satellite Radio's are finally available as a dealer installed accessory. |
Michael Di Salvo Wins! -
2002, Jun 03 The 3.5L headers donated by Bob Land Racing was won recently by NY resident Michael Di Salvo. |
Front Air-Lockers Are Here! -
2002, May 30 After much anticipation ARB's front Air-Lockers for Isuzu's are finally available! |
Hubs Explained -
2002, May 11 Are your auto-hubs clicking? Thinking of switching to manuals? Have SOTF and want better gas mileage? Read this article to find answers |
VX Offered at New Low Price! -
2002, May 06 One of the dealers in the PI network is offering VXs at incredible prices. Now is your chance to own one! |
Ball Joint Flip/Spacer Howto -
2002, May 02 With these instructions you can flip your upper ball joint to allow for more downtravel in the IFS front end. |
2002, Apr 29 A brief recap of the fun run in Uwharrie, NC |
Inside the Isuzu 3.2 -
2002, Apr 07 Pic's of the Inside of a 3.2L Engine |
VX2 Concept -
2002, Mar 07 Isuzu's New Extreme SUV |
Isuzu receives many names -
2002, Mar 07 In a search for the name for Isuzu's new SUV, many people have responded |
Mud Report -
2002, Mar 07 Chris Perosi tours the Pine Barrens with a group of Zu's |
Isuzu engine wins tech award -
2002, Mar 07 ISUZU Diesel Takes Technology of the Year Award: Japan's Prestigious Researchers & Journalist Conference Selects Isuzu for 1998 Technology of the Year Trophy
Isuzu wins warranty award -
2002, Mar 07 The Isuzu Trooper and Isuzu Rodeo have been awarded IntelliChoice®'s GoldStar for their lease programs |
Isuzu sponsors Bike Race -
1999, May 29 Isuzu Sponsors 1999 Race Across America |
Amigo Wins Baja 500 -
1999, Jun 17 John Kearney wins Class 3 in this off-road race |
Bob Land Interview -
2002, Mar 07 Planet Isuzoo is very proud and excited to bring you this exclusive interview with Mr. Bob Land, Owner and Driver of Land Racing |
Pine Barrens trail report -
2002, Feb 25 Conway, Mike and Doug let a group through the PB in NJ. Read more about the adventure. |  |
Uwharrie April 2002 -
2002, Feb 11 Time for one of the annual Uwharrie NC runs. Get more info here. |
Troubleshooting the Shift on the Fly Mechanism -
2002, Feb 05 If you truck is stuck in 2wd or 4wd or the shift on the fly mechanism isn't working, here is the fix. |
How to adjust your own valves. -
2002, Feb 03 Sam Isuzu teaches us how to adjust your valves. |
Installing 6.5i woofers under a Trooper rear seat -
2002, Feb 03 Todd Schaffer's instructions on installing 6 1/2" woofers under a Trooper rear seat. |  |
CALMINI: ISUZU Accessories Bible -
2002, Feb 03 CALMINI Products Inc. new catalog of products for your Isuzu. |
Amigo/Rodeo Boulder Bars -
2002, Feb 03 Dan gives us instructions on how to make Boulder Bars. |  |
Win a FREE Pair of Bob Land Headers!! -
2001, Dec 15 Enter to win a free pair of headers that fit a Rodeo or Rodeo Sport with the Isuzu V6 engine. Courtesy of Bob Land Racing Inc. |
Axiom Named SUV Of the Year -
2001, Dec 15 Auto International Association (AIA) has named the 2002 Isuzu Axiom its SUV of the Year.
Ascender is Coming! -
2001, Dec 15 The new 2003 Isuzu Ascender will soon take the place left vacant from the Trooper as isuzu's top-of-the-line product. |  |
High-Output Axiom! -
2001, Dec 15 Isuzu takes it's newest product and makes a warrior out of it. |  |
Front Bearing Repack -
2001, Dec 15 It needs to be done every 30k miles, read Dave's writeup to
learn how. |  |
16x8 Wheels on an Amigo -
2001, Dec 15 Give your Amigo a little bit better stance for the wider t
ires. |
Amigo Sunroof Tint -
2001, Dec 15 Keep things a little cooler in your 2nd gen with some easy sunr
oof tint. |
Rancho RS-9000 Shocks -
2001, Dec 15 How to make Rancho 9000s fit a 2nd gen Amigo |  |
Soft Top Quick Release -
2001, Dec 15 Adding a quick release to the soft top on an 1998 Amigo |
Grill Gaurd & Lights -
2001, Dec 15 Changing the look of the 2nd Gen Amigo with a grill guard and
some lights. |
Manual Hub Conversion -
2001, Dec 15 Converting to Superwinch manual hubs on a SOTF Amigo |  |
Amigo Dynamat Installation -
2001, Dec 15 Installing dynamat to quiet down a 2nd gen Amigo |
Amigo Audio Upgrades -
2001, Dec 15 Wade walks us through upgrading his stereo in his 98 Amigo |
Isuzu Deals -
2001, Dec 15 Here's the latest purchase & lease info on Isuzu vehicles. |
ARB Logo Hats & Shirts! -
2001, Oct 04 ARB logo merchandise discounted for planetisuzoo members. |
ARB Project Trooper -
2001, Sep 23 ARB's Project Trooper is powering up. Take a look at this awesome beast and some of it's weapons! |  |
2.6l Electric Fan Upgrade -
2001, Sep 18 Kevin Wolford explains how to add an electric fan for increased cooling on first-gen Troopers. |
Spare Tire Attachment Conversion -
2001, Sep 17 Dave walks us through how to convert from bolts to lug nuts to hold the spare tire on, and how to use Thule's "Spare Me" carrier. |
Uwharrie Fun Run October 2001 -
2001, Sep 10 Its time again, the great gathering in NC. |
Protection Plan 2 Added Coverage! -
2001, Sep 10 Planet Isuzoo members can now upgrade their new vehicle's warranty coverage at a discount, thanks to American Isuzu Motors. (AIMI) |
Bob Land Wins Again! -
2001, Sep 08 Bob Land captures another 1st place finish in this year's 2001 Australian Safari |
Door Popping Noise -
2001, Aug 23 Have a popping noise everytime you open the door on your 98+ Rodeo or Rodeo Sport? We've got the cure for you! |
New Planet T-Shirts -
2001, Aug 23 Brand new planetisuzoo t-shirts are here. Order one today and show everyone your support for Isuzu & Planet Isuzoo. |
Axiom Lift & LSD install -
2001, Jul 26 Adding a body lift, suspension lift and installing an LSD in a new Axiom |  |
Uwharrie July 2001 Review -
2001, Jul 30 Another successful and fun run. Read about it and view the pictures/video. |
DIY Laptop Stand -
2001, Jul 09 Dave Chang and Jason Basham fabbed up a nice removable laptop stand for the truck. |
Johnstown Pennsylvania Annual Toys for Tots Trailride -
2001, Jul 09 Nearly a hundred off-road enthusiasts converged on the small frozen town of Johnstown, PA. for this ride. |
Axiom Ride & Drive 2001 -
2001, Jun 23 Planet staff member Mike S. and club member Mark Gross test drive the all new Isuzu Axiom at the Axiom Ride & Drive Program in Atlanta, GA. |
Timing Belt Recall -
2001, Jun 22 1998-2000 Rodeo And Amigo owners with 2.2 Engines should read this. |
Monster Isuzu Pup -
2001, Jun 29 Chuck from Orlando, Florida built this MONSTER Pup - see video and pics |  |
Joe Isuzu Interview -
2001, Jun 11 Following an 11-Year Hiatus, Joe Isuzu Makes a Triumphant Return to TV – Only this Time There’s a Twist |
VX Rodeo and VX Amigo (RS) Pics -
2001, Jun 05 When Mike and I (Tad) visited Isuzu HQ right before Moab, we got to see the VX versions of the Rodeo and Amigo (now RS) |  |
July 2001 Uwharrie Run -
2001, Jul 18 Planetisuzoo will be making its annual July trip to Uwharrie the weeeknd of July 20-22 2001. |
Calmini 3" Suspension Lift -
2001, Sep 10 Wade Ripkowski walks us through the install of a 3" lift kit on a 2nd generation Isuzu Amigo.
Isuzu's New Concept Vehicle -
2001, May 27 Isuzu debuts another concept vehicle - the GBX at the North American Auto show in Detroit. For the inside story read Isuzu's contributing journalist Steve Laser's article reprinted here from the latest issue of Isuzu's InRoads Magazine. |  |
ProLine Roof-Rack Installation -
2001, Mar 21 A detailed account of the installation on a '99 Amigo Hardtop |
Planet Member Wrecks VX -
2001, Mar 21 Planet Member "Tone Monday" Wrecks His 99 Vehicross |
UWharrie - Fun-Run 1 -
2001, Jul 29 With the destination set, the battle cry sounded, Isuzu's came from far and wide to the UWharrie National Forest, near Troy, North Carolina |
Ocala 2 Fun-Run Report -
2001, Mar 21 Ocala 2 -- "The Sequel" Pictures, videos, and a trail report from Florida |
Tinting Your Headlights -
2001, Mar 21 Shaun tells us how he tinted his headlights with window tint |
Trail Riding in the Winter Wonderland - Iceland -
2001, May 27 Gary Hargrove describes wheeling in Iceland and the mods to his 98 Trooper |  |
New Axiom Pricing -
2001, Mar 15 American Isuzu Announces Pricing on 2002 Axiom; Rugged, Yet Refined Crossover
SUV Begins Retail Sales, April 10 |
INDEPENDENT4x Launches Website -
2001, Mar 14 INDEPENDENT4x announces the launch of their new website, www.INDEPENDENT4x.bigstep.com, specializing in ISUZU off-road accessories. |
Leaking Intake Gaskets on 3.2l -
2001, May 27 Have a rough idle, check eng. light on, air leak noise from under hood. Intake gasket breaking may be the cause on the 98 and newer v/6 Trooper and Rodeo
Powertrax LOCK-RIGHT: in Isuzu 17 spline axles -
2001, May 27 Dr. Sean Michael (a.k.a., WomBAT Man) takes us through exactly how to install a Powertrax Lock-Right in an Isuzu 10-bolt Diff. |  |
ARB Locker Install -
2001, Mar 13 Sam Isuzu describes how to install an ARB locker in an Isuzu 12-bolt differential. |
Gilmer Trail Report -
2001, Mar 12 Thanksgiving weekend there was a gathering at the Texas Motorized Trails Commision Barnwell Mtn. facility in Gilmer, Tx. The run was sponsored by the 4x2 Pre-Runner club. Joe gives us a report. |
Tera Low Install Writeup -
2001, Mar 12 Fernando Rivero has been kind enough to write up his brand new Tera-Low gear install. |
Isuzu Axiom Presentation -
2001, Mar 12 We received a multimedia attachment about the Isuzu Axiom for you to download. |
Commercial Sway-bar Disconnects -
2001, Mar 12 Rockstomper has announced that they are starting to sell sway-bar disconnects for Isuzu trucks. Visit their website at http://www.rockstomper.com for more information. |
Hotrod-offroad.com Back in Business -
2001, Mar 12 We just received a message from Dan at Hotrod-offroad.com. |
Joe Isuzu Fan site found -
2001, May 27 Go check out www.joeisuzu.com |
Joe Isuzu Is Back!!! -
2001, Mar 12 Isuzu announced recently that they would hire actor David Leisure to play Joe Isuzu for another set of Isuzu commercials. You may remember Joe for his Isuzu ads in the late 80s. We have the press release, and some of his commercials. |
DIY Sway bar disconnects -
2001, Mar 12 Are you looking for a cheap way to gain some articulation on your IFS isuzu? |
